| WTB PCB WD5000AAKS http://forum.hddguru.com/viewtopic.php?f=15&t=16694 |
Page 1 of 1 |
| Author: | Kevin Robert [ August 13th, 2010, 15:38 ] |
| Post subject: | WTB PCB WD5000AAKS |
Two drives on same sata power cable got zapped by faulty psu here's hopefully the right info to maybe get a pcb swap done They will not power up at all and my skills go as far as unscrewing a torx lol, My brother however can solder like a champ hope someone can help me as one of the drives has all my kids pictures on it (I was going to back them up today and karma bit me in the ass). If you need more info please let me know. Drive 1: Mdl: wd5000aaks – 65ygao Date: 30 oct 2007 Dcm: dhrcht2cab Board number on label: 2061-701477-900 AD Board number on PCB: 2060-701477-002 REV A Drive 2: Mdl: wd5000aaks – 65ygao Date: 30 oct 2007 Dcm: hhncnt2mbb Board number on label: 2061-701477-900 AD Board number on PCB: 2060-701477-002 REV A |
| Author: | drc [ August 13th, 2010, 15:54 ] |
| Post subject: | Re: WTB PCB WD5000AAKS |
You can't do that |
| Author: | Kevin Robert [ August 13th, 2010, 16:48 ] |
Short of DR I am screwed then ? |
| Author: | drc [ August 13th, 2010, 17:03 ] |
Pretty much. It doesn't have to be expensive DR though. We have several forum members in Canada, try lcoughey or starling |
| Author: | Kevin Robert [ August 13th, 2010, 17:12 ] |
Thank you very much for your help I will PM those two and see what they say My situation gets worse than just that though, I had the PCB's off and on top of drives I wanted to see if they were burnt and my son took them whilst I was in the washroom so now I have no clue which is for which drive yeesh!!!! If any Canadians or even better Winnipeggers read this and can help please tell me |
| Author: | drc [ August 13th, 2010, 17:53 ] |
That's fine, with the proper equipment the necessary data from the PCB can be reconstructed from the drive |
| Author: | donordrives [ August 13th, 2010, 23:17 ] |
In case you still need the boards, I have a couple. Here is the search result from the site: http://www.donordrives.com/index.php/catalogsearch/result/?q=2061-701477-900+AD |
| Author: | drc [ August 14th, 2010, 8:27 ] |
But there's no reason that he would need them. |
| Author: | fzabkar [ August 17th, 2010, 7:08 ] |
Kevin Robert wrote: Two drives on same sata power cable got zapped by faulty psu here's hopefully the right info to maybe get a pcb swap done Upload detailed photos of the boards and one of us will try to help you with a no-cost DIY fix. |
