ATA Convertor
http://forum.hddguru.com/viewtopic.php?f=15&t=16751
Page 1 of 3
Author:  ppumkin [ August 19th, 2010, 16:37 ]
Post subject:  ATA Convertor
Any body know where i can purcahse ce-ata to ide - to be used with hs161jq type drives
thanks
Author:  donordrives [ August 19th, 2010, 23:05 ]
Post subject:  Re: ATA Convertor
One comes with PC3000, I know that much.
Author:  ppumkin [ August 20th, 2010, 12:00 ]
So nobody here can recover data from a CEATA hdd.. nice.
Ill just go and buy an EEEPC...
<grumbles>
Author:  ppumkin [ August 20th, 2010, 12:10 ]
http://forum.hddguru.com/ata-adaptors-available-t12764.html
2009 - no solution..
but now..
SD-SDIO-MMC-CEATA-Device-HVP-Flyer.pdf [201.49 KiB]
Downloaded 1418 times
PB-SD2.1_MMC4.4-CE_ATA-AHB-Mem-Ctrlr-IP.pdf [185.58 KiB]
Downloaded 1235 times
Author:  ppumkin [ August 20th, 2010, 12:20 ]
Germany, Austria, Switzerland,Italy, Belguim
TRIAS Mikroelektronik GmbH
Moerser Landstrasse 408
47802 Krefeld
Germany
Tel : +49-2151-95301-0
Fax: +49-2151-95301-15
Email: info@trias-mikro.de
UK, Ireland, France, Spain, Portugal, Norway
EDA4YOU
Salbeiweg 65
76149 Karlsruhe
Germany
Tel: +49-721-66 37 922
Fax: +49-721-66 37 921
Email: info@eda4you.eu
Finland, Sweden, Denmark
47802 Krefeld
Germany
Russia, Poland, Romania
47802 Krefeld
Germany
Israel
Arasan Chip Systems, Inc.
2010 North First Street,
Suite 510, San Jose
CA 95131, USA
Tel: +1-408-282-1600
Fax: +1-408-282-7800
Email: sales@arasan.com
Author:  donordrives [ August 20th, 2010, 23:10 ]
Anyone who owns a PC3000 UDMA can recover data from it. The adapter comes with a purchase of UDMA
Author:  fzabkar [ August 21st, 2010, 8:20 ]
If you're just doing logical recovery, could you make do with something like the following?
StarTech IDE1810U2Z Aluminum 1.8" USB 2.0 External Hard Drive Enclosure:
http://www.startech.com/item/IDE1810U2Z ... osure.aspx
Author:  ppumkin [ August 21st, 2010, 8:33 ]
Thanks for the link fzabkar- it says ceata zif/lif ; but there is no picture inside to actaully show whether its the smaller in width cable than the ordinary one.
I shall call e-buyer(uk associate of that site)- maybe somebody will be able to tell me. It should be good for use with logical recovery..
Or ill just buy it and see.
Author:  networkpc3000 [ August 21st, 2010, 15:59 ]
hi,
if you just need external enclosure i have cheap one in stock. :)
Author:  drc [ September 27th, 2010, 13:12 ]
At least some of these drives are not CE-ATA
Author:  Eric Lee [ September 27th, 2010, 21:34 ]
Hi, Do you need the 1.8" CE ATA to 3.5" IDE and 2.5" adapter? If so, I have it, :)
Thanks,
Eric
Author:  ppumkin [ September 28th, 2010, 11:46 ]
Ah at last!
Its like this is it?
The zif cables are the ones you can buy everywhere for like the 1.8" Toshiba Apple drives or another.
Please notice this Samsung is almost 1/3 of the size and its CE technology.
Thanks.
Author:  ppumkin [ October 1st, 2010, 10:14 ]
Hey ppumkin - is that what you need (see attached photo)
Ahh thanks Mate!!
PS Its not MMC- its actually sata..
Good tip anonymous!
PS This forum is da bomb with help!
Thanks for the help...
If you need one pm me.
Author:  drc [ October 1st, 2010, 10:31 ]
I do not think this is accurate
Author:  ppumkin [ October 1st, 2010, 10:43 ]
What is not accurate- the MMC part or the SATA part.
Or both?
Do you have the pinouts for YPM09657 Marvel chip?
Author:  drc [ October 1st, 2010, 11:07 ]
The SATA part. Samsung's data sheet clearly states that hs161jq has a CE-ATA interface which is based on MMC. That said, there is a think-outside-the-box solution that does not require adapters at all...
Author:  ppumkin [ October 1st, 2010, 11:18 ]
I know- that's what i have been following the whole time after MMC. That's why this sata plug surprised me.
God. why is my box so blingin big...
Only thing i can think is use the ATA version of the pcb. But i assume that is not straightforward swap either..
Author:  Persia2500 [ October 1st, 2010, 12:10 ]
that's ZIF ATA/100 if you got an IPod replace the drive , IPod usb connection works as ATA convertor .
you might need a $20 micro sata => normal sata depending on your recovery case .
Those ZIF connectors on pcb are mostly designed for max 15 time connect/disconnect.
Author:  Persia2500 [ October 1st, 2010, 14:20 ]
if you got the drive orginal ZIF cable then its only a 5$ convertor
http://www.drivestar.org/product/converter/converter.htm
Author:  drc [ October 1st, 2010, 14:53 ]
That is for regular ZIF. CE-ATA is different.
Page 1 of 3 All times are UTC - 5 hours [ DST ]
