WD5000AAKS Dead
http://forum.hddguru.com/viewtopic.php?f=15&t=17216
Author:  saleof [ October 2nd, 2010, 5:05 ]
Post subject:  WD5000AAKS Dead
Hello Guru's
I have WD5000AAKS which is dead. I need some help recovering data from this drive. I have checked all the DIOD's (D3, D4) and registers( R67 and R64) all seems to be fine.
Is the smooth chip busted? or the internal motor? How can I diagnose this issue.
PCB: 2061-701477-800 AF
DCM: DBRCHV2CBN
SO
Author:  saleof [ October 2nd, 2010, 16:05 ]
Post subject:  Re: WD5000AAKS Dead
I am looking for Smooth chip, dose any know where to buy this chip?
SO
Author:  hddmania [ October 3rd, 2010, 11:53 ]
If you just needs parts for this PCB, You can contact either ERIC or SUNNY. They have what you need in stock.
Author:  networkpc3000 [ October 3rd, 2010, 18:02 ]
hi,
i have this model of PCB in stock. it had to do FW transfer operation. i can help you do that. please feel free to contact me by email or MSN. if you just want the smooth chip for try. you can take it from similar PCB locate. but be careful. if any mistake PCB will kill the read/write head. make Data recovery cost more higher. good luck
Author:  fzabkar [ October 3rd, 2010, 20:10 ]
You can test the motor windings by measuring their resistances on the 200 ohms range of your multimeter. They should measure around 3 ohms.
Author:  Eric Lee [ October 3rd, 2010, 21:45 ]
Hi, I have this working PCB and smooth chip for sale, pls contact my hotmail.
Thanks.
Eric
