Need a PCB for Seagate Momentus 5400.3 160GB
http://forum.hddguru.com/viewtopic.php?f=15&t=17397
Author:  sarang2590 [ October 19th, 2010, 23:45 ]
Post subject:  Need a PCB for Seagate Momentus 5400.3 160GB
Hello friends,
I am from india. My HDD is dead due to malfunction in Chip.
I want a replacement for it.
It wud be very helpful if any1 can help me and also tell prices.
Model No: ST9160821A
PN: 9S1034-508
FW: 3.ALE
As on Sticker on PCB:
100390530----H---E83744KF
Its urgent, waiting 4 ur replies.
Thanks.
--Sarang
Author:  Eric Lee [ October 21st, 2010, 7:50 ]
Post subject:  Re: Need a PCB for Seagate Momentus 5400.3 160GB
Hi, I have this kinds of working PCB in stock, pls contact my hotmail to see if I can help or not.
Eric
Author:  fzabkar [ October 21st, 2010, 17:01 ]
Can you describe the failure symptom?
If you upload a detailed photo, one of us may be able to help you repair your board, or at least confirm that the problem isn't elsewhere.
Author:  networkpc3000 [ October 21st, 2010, 19:41 ]
hi,
i have this kind of PCB in stock. would you like to let me know the models of your PCB which brand on PCB? it should with REV X
Author:  sarang2590 [ October 22nd, 2010, 11:32 ]
Here are screen shots given:
See details in my below post. Please help.
Author:  sarang2590 [ October 22nd, 2010, 11:36 ]
I have submitted SS of PCB.(wait till its approved by Mods)
Actually i got it repaired once. But instead he removed some components and made it work. I think it is same problem again. The drive is not detected. But when i connect it to PC using USB converter, sometimes it makes chirping sounds. What should be my problem? Also it gets up somewhat heated up when connect it through USB.
I was using it with same USB interface.
Help Awaited. Thanks.
Author:  fzabkar [ October 23rd, 2010, 3:31 ]
The chirping sounds could be a symptom of stiction. This occurs when the heads come to rest on the platters instead of their normal parking position.
Does the SMOOTH motor controller chip get hot?
BTW, I suspect that the previous repairer removed a 5V TVS diode. If so, then this would suggest that your drive was subjected to an overvoltage. Have you changed your power supply since then, or was the failure due to human error?
