 Post subject: WANTED: PCB for SAMSUNG BF41 002841A 01
PostPosted: December 5th, 2010, 22:17
Okay, so a couple of days ago ... I accidentally plugged in the wrong power supply for the G3 external HDD and then I started to smell smoke. Now, the HDD won't spin, click or power up ... which leads me to believe that there is a possibility that I can retrieve my data if I can find a replacement PCB.
So far, I have had no luck finding a match. Google is practically sending me little to no results for any of the numbers I've found from the current PCB.
If anyone can help, I would be so appreciative. I live in Australia, and am almost willing to pay for a new PCB to be delivered to me internationally if there is no other hope.
The details I've gotten from the current PCB is as follows:
* BF41-00284A 01 (etched on board)
* PAAZE4MDA80772 (found under barcode on white sticker, located on sata connector)
* 8818827-TFJ2
YPM25031
1805 A1P T TW
(all found on one square chip)
* SAMSUNG 013
K4H561638J-LCCC
H5616 WR84776AU
(found on one rectangular chip)
Thank you.
 Post subject: Re: WANTED: PCB for SAMSUNG BF41 002841A 01
PostPosted: December 5th, 2010, 23:01
Double post different name. Look at your other post I told you how to find what you need.
Iorana Haraharaini
PostPosted: December 6th, 2010, 2:01
first following poehere answer to do. mostly it will help you figure it out. if still no help i have this PCB in stock. please feel free to contact me by email or MSN if need.
data recovery service[/b]
