 Post subject: Western Digital WD10EAVS - please help
PostPosted: December 8th, 2010, 14:54
This WD WD10EAVS 1Tb was in a WD MyBook but it stopped working, no noise, no smell just as dead as a dodo.
Upon testing the power supply I found it was supplying 20V instead of 12V, so I guess this is the cause.
I'd like to get a similar logic board and replace it but apparently you need to swap the U12 ROM chip. My board has not got a U12 ROM chip so any ideas would be appreciated.
Also I've removed diodes D3 and D4 (I read that this might work) but still no good.
Ideas please!
 Post subject: Re: Western Digital WD10EAVS - please help
PostPosted: December 8th, 2010, 18:17
Did you check R64 and R67?
Did you try connecting the drive directly to your computer's motherboard? It could be that there is an additional problem on the USB-SATA bridge board inside the enclosure.
PostPosted: December 9th, 2010, 14:45
Hi, I'll check R64 and R67, what should their values read.
Also, when I plug the drive onto the mother board, the PC switches itself off and wont turn on again untill the drive is removed again.
Thanks.
PostPosted: December 9th, 2010, 16:16
D3 is still present in this photo:
download/file.php?id=2926&mode=view
Have you removed D3 since the photo was taken?
R64 and R67 should measure 0 ohms.
If the PC won't power up, then there must be another short circuit. Measure the resistances between ground and each of the +5V and +12V pins at the SATA power connector.
Here is the pinout:
http://pinouts.ru/Power/sata-power_pinout.shtml
PostPosted: December 10th, 2010, 4:55
Yes,
D3 was definitely removed, and still same problem. The resistors are reading 0ohms as they should. I'll meter the pins on the SATA connector as you suggest.
Thanks.
PostPosted: December 13th, 2010, 0:10
hi,
i have this PCB in stock. please feel free to contact me by email or MSN if need. i can help with firmware transfer too.
data recovery service[/b]
Users browsing this forum: Google [Bot] and 9 guests
