HDD GURU FORUMS
http://forum.hddguru.com/
Fujitsu MHW2120BH CA06820-B38800AP
http://forum.hddguru.com/viewtopic.php?f=15&t=17788
Page 1 of 1
Author:  scxy1234 [ November 26th, 2010, 21:02 ]
Post subject:  Fujitsu MHW2120BH CA06820-B38800AP
Friend's drive MHW2120BH CA06820-B38800AP failed with data not backed up. Is it necessary to get exactly the same PCB model (the few I've found are very expensive), or is it possible that a drive board that, say, begins with CA06820- might work?
Any help is appreciated.
Steve
Author:  GiGaBiTe [ December 5th, 2010, 3:11 ]
Post subject:  Re: Fujitsu MHW2120BH CA06820-B38800AP
If the controller board is bad, you need to get an identical one with the same firmware.
Author:  poehere [ December 5th, 2010, 23:07 ]
What failed. Power supply, heads, internal SA. You do not give us a whole lot to go on. This needs a better diagnostics in order to go on. Tell us more details of what is failing and what the drive is doing.
Author:  networkpc3000 [ December 6th, 2010, 1:55 ]
if you need fine out the PCB for replace please post the model of your PCB. i can check for you.
http://www.phpbb.com/
