HDD GURU FORUMS
http://forum.hddguru.com/
Need PCB for WD5000AAKS-22A7B2
http://forum.hddguru.com/viewtopic.php?f=15&t=17821
Page 1 of 1
Author:  CzarinaOz [ November 29th, 2010, 20:17 ]
Post subject:  Need PCB for WD5000AAKS-22A7B2
This HDD uses two 320 platters that are reduced to equal 500GB so doing a search usually turns up a 640GB HD. I only need the PCB.
MDL: WD5000AAKS-22A7B2
DCM: HANNNT2CA
PCB: 2061 701590 L00 AA
Manufacture Info: 18 Nov. 2008, Malaysia
If any other information about this HD is needed?
Author:  CzarinaOz [ November 30th, 2010, 14:23 ]
Post subject:  Re: Need PCB for WD5000AAKS-22A7B2
More information:
The problem occured when I had the SATA hooked via a USB (converter) in my laptop - I couldn't close the program I was using from the HD in order to safely remove the USB connection - I pulled it out anyway. I heard a screetch from the HD and from that point on, it spins up but whines and clicks. I opened it and the stylus moves across the platters fine.. so I am assuming it is a problem with the primary circuit board...?
BIOS will show the HD but after attempting to read past primary POST it cannot load and just gives up and shuts the drive down. CMOS will not see it.
Author:  drc [ November 30th, 2010, 14:47 ]
Maybe, but now you have almost certainly damaged the media surface
At any rate, just attaching a new PCB wouldn't have solved your problem anyway, as these drives have unique information stored to the PCB
Author:  networkpc3000 [ November 30th, 2010, 21:58 ]
as Mr.drc said. since you open it bring more troubles about dust go inside will damaged platters & head. and it looks no the problem in beginning. more look like got crash head. need to send it to data recovery company for process.
http://www.phpbb.com/
