Western Digital WD10EAVS - please help
http://forum.hddguru.com/viewtopic.php?f=15&t=17932
Author:  jaseandwave [ December 8th, 2010, 14:54 ]
Post subject:  Western Digital WD10EAVS - please help
This WD WD10EAVS 1Tb was in a WD MyBook but it stopped working, no noise, no smell just as dead as a dodo.
Upon testing the power supply I found it was supplying 20V instead of 12V, so I guess this is the cause.
I'd like to get a similar logic board and replace it but apparently you need to swap the U12 ROM chip. My board has not got a U12 ROM chip so any ideas would be appreciated.
Also I've removed diodes D3 and D4 (I read that this might work) but still no good.
Ideas please!
Author:  fzabkar [ December 8th, 2010, 18:17 ]
Post subject:  Re: Western Digital WD10EAVS - please help
Did you check R64 and R67?
Did you try connecting the drive directly to your computer's motherboard? It could be that there is an additional problem on the USB-SATA bridge board inside the enclosure.
Author:  jaseandwave [ December 9th, 2010, 14:45 ]
Hi, I'll check R64 and R67, what should their values read.
Also, when I plug the drive onto the mother board, the PC switches itself off and wont turn on again untill the drive is removed again.
Thanks.
Author:  fzabkar [ December 9th, 2010, 16:16 ]
D3 is still present in this photo:
download/file.php?id=2926&mode=view
Have you removed D3 since the photo was taken?
R64 and R67 should measure 0 ohms.
If the PC won't power up, then there must be another short circuit. Measure the resistances between ground and each of the +5V and +12V pins at the SATA power connector.
Here is the pinout:
http://pinouts.ru/Power/sata-power_pinout.shtml
Author:  jaseandwave [ December 10th, 2010, 4:55 ]
Yes,
D3 was definitely removed, and still same problem. The resistors are reading 0ohms as they should. I'll meter the pins on the SATA connector as you suggest.
Thanks.
Author:  networkpc3000 [ December 13th, 2010, 0:10 ]
hi,
i have this PCB in stock. please feel free to contact me by email or MSN if need. i can help with firmware transfer too.
