| Need pcb for Samsung HD753LJ http://forum.hddguru.com/viewtopic.php?f=15&t=17937 |
Page 1 of 1 |
| Author: | Alwin [ December 9th, 2010, 7:35 ] |
| Post subject: | Need pcb for Samsung HD753LJ |
Hi guys, I need a pcb for a Samsung 750GB HD753LJ Drive with the following characteristics: HD753LJ(B) Date: 2008.08 PCB: TRINITY 32MB REV5 BF41-00206B R00 Drive has no spinup, TVS diodes are fine, 0ohm resistor is fine and disks/motor is free. Hope a close match will get this drive to work again. Thanks for your efforts, Alwin |
| Author: | Cosworth [ March 17th, 2011, 7:19 ] |
| Post subject: | Re: Need pcb for Samsung HD753LJ |
I need the exact same board,with exact same problem Rev 4 board wont work |
| Author: | fzabkar [ March 18th, 2011, 18:32 ] |
Cosworth wrote: I need the exact same board,with exact same problem Rev 4 board wont work Can we see a detailed photo of the component side? If you have a digital multimeter, there are a few simple measurements you can make. Your replacement PCB will be very useful for comparison. |
| Author: | Mikippp [ March 19th, 2011, 17:14 ] |
Cosworth wrote: I need the exact same board,with exact same problem Rev 4 board wont work Hi, PCBs TRINITY 32MB REV4 and TRINITY 32MB REV5 are interchangeable The problem is not the PCB REV, but version of the ROM inside the CPU Mikippp |
