 Post subject: WD5000AAVS - Need PCB and Firmware transfer
PostPosted: December 28th, 2010, 15:05
Hey guys - I'm looking for someone located preferably in North America that can help me w/ a PCB / firmware transfer on the drive listed below. Please let me know if you can help. Thanks!
WD Caviar GP 500GB
WD5000AAVS - 00ZTB0
WWN: 50014EE1010042A2
SN: WCASU4021458
Controller IC: 88i6745-TFJ1
Motor Combo IC: L6284 3.1
Board #: 2061-701444-J00
 Post subject: Re: WD5000AAVS - Need PCB and Firmware transfer
PostPosted: December 28th, 2010, 15:18
What is wrong with your PCB?
PostPosted: December 28th, 2010, 15:59
The drive intermittently is detected in the BIOS but will detect fine when hooked up to DDI. However, when I image using DDI the imaging seems to go very slow (~ 3 weeks), despite the media tests coming back all green. After about 2 minutes, the drive re-powers itself and throws a "Drive returns wrong LBA number with error" message, before continuing on at its normal slow pace. It will periodically throw that error message going forward as well. Also get tons of drive read timeouts and seems to write a lot of 0's at times.
I've tried various tricks w/ DDI to try and get it to image but it keeps throwing that error. I've consulted Deepspar support for additional help and they've helped me confirm that it is almost certainly the PCB. I don't have a PC3000 though so I'm not able to do a firmware transfer on my own.
Users browsing this forum: No registered users and 37 guests
