 Post subject: WD2500JS-75MHBO 2060-701335-003 Rev-A
PostPosted: January 5th, 2011, 17:34
This drive is clicking, usually in a series of three. Occasionally (especially when cold), I can coax it into mounting properly and retrieving data but it has now deterioriated greatly. The clicking sounds like some type of attempt to re-sync / park heads. No scraping or other mechanical failure is evident. I'm on my last practical guess here and am going to try a board swap. Someone shoot me a message if they have one matching that listed in the subject.
 Post subject: Re: WD2500JS-75MHBO 2060-701335-003 Rev-A
PostPosted: January 8th, 2011, 19:06
A board swap won't work. That said, remove the board and gently clean any oxidisation from the 20 preamp contact pads with a soft white pencil eraser.
Otherwise, clone your drive ASAP sector-by-sector using a utility that understands how to work around bad sectors.
See delays-found-hard-disk-t18034.html
