| WD2500JS-75MHBO 2060-701335-003 Rev-A http://forum.hddguru.com/viewtopic.php?f=15&t=18153 |
Page 1 of 1 |
| Author: | joshr [ January 5th, 2011, 17:34 ] |
| Post subject: | WD2500JS-75MHBO 2060-701335-003 Rev-A |
This drive is clicking, usually in a series of three. Occasionally (especially when cold), I can coax it into mounting properly and retrieving data but it has now deterioriated greatly. The clicking sounds like some type of attempt to re-sync / park heads. No scraping or other mechanical failure is evident. I'm on my last practical guess here and am going to try a board swap. Someone shoot me a message if they have one matching that listed in the subject. |
| Author: | fzabkar [ January 8th, 2011, 19:06 ] |
| Post subject: | Re: WD2500JS-75MHBO 2060-701335-003 Rev-A |
A board swap won't work. That said, remove the board and gently clean any oxidisation from the 20 preamp contact pads with a soft white pencil eraser. Otherwise, clone your drive ASAP sector-by-sector using a utility that understands how to work around bad sectors. See delays-found-hard-disk-t18034.html |
