 Post subject: wanted: parts for Maxtor DiamondMax Plus 8
PostPosted: January 12th, 2011, 20:36
I'm going to try and swap logic boards on a maxtor diamondmax plus 8 that died. My friend needs the data off it, so I need to swap some parts.
 Post subject: Re: wanted: parts for Maxtor DiamondMax Plus 8
PostPosted: January 13th, 2011, 4:01
Can you tell us the fault symptom?
If this is your board ...
uploaded_images/6472_N40P_1.jpg
... then I believe you will need to move the 8-pin ST25P10V6 (= ST Microelectronics M25P10-V6) flash memory chip, or its contents, from patient to donor.
M25P10V6, M25P10VP, ST Microelectronics, 1 Mbit (128 Kbit x 8) serial flash memory:
http://www.datasheetarchive.com/pdf/get ... .pdf&scan=
PostPosted: January 13th, 2011, 11:05
Hi, We have this kinds of working PCB in stock, pls contact my hotmail to see if I can help or not.
Thanks, Eric.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: January 13th, 2011, 17:58
Just to make sure, the larger pin says "Ardent C9-C1" and the smaller (rectangular) says "hynnix 303A" on it. Is this the correct pcb for my hard drive?
PostPosted: January 14th, 2011, 5:57
I'm not a data recovery professional, so I can't answer your question.
However, the hynix part is an SDRAM. The "303" may be a YWW (Year / Week) date code. The actual part number begins with "HY". In any case you don't need to worry about the SDRAM as long as it has the correct capacity.
PostPosted: January 16th, 2011, 22:53
hi,
i have this PCB in stock. please contact me by email or skype.
data recovery service[/b]
