| wanted: parts for Maxtor DiamondMax Plus 8 http://forum.hddguru.com/viewtopic.php?f=15&t=18244 |
Page 1 of 1 |
| Author: | ktpmm5 [ January 12th, 2011, 20:36 ] |
| Post subject: | wanted: parts for Maxtor DiamondMax Plus 8 |
I'm going to try and swap logic boards on a maxtor diamondmax plus 8 that died. My friend needs the data off it, so I need to swap some parts. |
| Author: | fzabkar [ January 13th, 2011, 4:01 ] |
| Post subject: | Re: wanted: parts for Maxtor DiamondMax Plus 8 |
Can you tell us the fault symptom? If this is your board ... uploaded_images/6472_N40P_1.jpg ... then I believe you will need to move the 8-pin ST25P10V6 (= ST Microelectronics M25P10-V6) flash memory chip, or its contents, from patient to donor. M25P10V6, M25P10VP, ST Microelectronics, 1 Mbit (128 Kbit x http://www.datasheetarchive.com/pdf/get ... .pdf&scan= |
| Author: | Eric Lee [ January 13th, 2011, 11:05 ] |
Hi, We have this kinds of working PCB in stock, pls contact my hotmail to see if I can help or not. Thanks, Eric. |
| Author: | ktpmm5 [ January 13th, 2011, 17:58 ] |
Just to make sure, the larger pin says "Ardent C9-C1" and the smaller (rectangular) says "hynnix 303A" on it. Is this the correct pcb for my hard drive? |
| Author: | fzabkar [ January 14th, 2011, 5:57 ] |
ktpmm5 wrote: Just to make sure, the larger pin says "Ardent C9-C1" and the smaller (rectangular) says "hynnix 303A" on it. Is this the correct pcb for my hard drive? I'm not a data recovery professional, so I can't answer your question. However, the hynix part is an SDRAM. The "303" may be a YWW (Year / Week) date code. The actual part number begins with "HY". In any case you don't need to worry about the SDRAM as long as it has the correct capacity. |
| Author: | networkpc3000 [ January 16th, 2011, 22:53 ] |
hi, i have this PCB in stock. please contact me by email or skype. |
