| Wanted: Hitachi Deskstar PCB (164GB Sata) Urgent! http://forum.hddguru.com/viewtopic.php?f=15&t=18437 |
Page 1 of 1 |
| Author: | flatlanded [ February 1st, 2011, 20:02 ] |
| Post subject: | Wanted: Hitachi Deskstar PCB (164GB Sata) Urgent! |
Hi there, I need a PCB from a Hitachi Deskstar 3.5" 164GB Sata as soon as possible! I hope someone has one as I haven't had any luck so far. I'd need to Fedex overnight if possible. The numbers are: P/N: 0A3353 MLC: BA1957 164GB - Nov 2006 Model: HDS1616PLA380 Numbers on PCB: 0A29530 BA1790_ Z3A644 0RLB I tried using a very similar board but no joy. I spooled up but couldn't read. Thanks! |
| Author: | fzabkar [ February 2nd, 2011, 1:31 ] |
| Post subject: | Re: Wanted: Hitachi Deskstar PCB (164GB Sata) Urgent! |
A straight board swap will not work. You need to transfer unique, drive specific, adaptive information form patient to donor. These data are stored in an EEPROM chip. As for the original board, can you describe the failure symptom? If you upload a detailed photo, one of us may be able to help you repair your board. Many times the problem is only a shorted diode, in which case it can simply be removed. |
| Author: | fzabkar [ February 2nd, 2011, 6:07 ] |
To be safe, you need to transfer the 8-pin ICs at locations U7 and U5 from patient to donor. Your local TV/AV repair shop should be able to do this for you. Be aware that you must not damage these chips, as data recovery will become much more expensive if you do. Do you have a multimeter, preferably a digital one? |
| Author: | flatlanded [ February 2nd, 2011, 16:13 ] |
Yes I do. I guess I'd still need a PCB to transfer to. The one I have is similar but not identical, the numbers are different. |
| Author: | fzabkar [ February 2nd, 2011, 22:48 ] |
If you wish to troubleshoot your original board, the first thing I would do, after removing the board from the drive, is to set your meter on the 200 ohms range and measure the resistances of the TVS diodes at D3 (12V) and D4 (5V). Next, measure the resistance between power ground and each of the following: - pin #8 of U7 (M25P05VP supply pin) - pin #8 of U5 (S93Cxx supply pin) - pin #1 of the SDRAM (K4S281632I-UC60 supply pin, rear of PCB) - each pin of transistors Q1, Q2, and Q3 (2SC6052, 2SA1242) - coil L1 (100uH) - coil L3 (100uH) If none of the resistances are near zero, ie no shorts, then power up the board and measure the voltages at each of the abovementioned points. Be very careful not to slip with your probes, as serious damage may result. Wherever possible, use a soldered test point on a nearby copper plane rather than a pin on the component itself. |
