 Post subject: Wanted: Hitachi HTS723232L9SA6
PostPosted: May 9th, 2011, 12:06
I am looking for a donor for heads (although a match for all components (board, FW, etc.) is preferred. Info below:
Model: HTS723232L9SA6
P/N: 0A72042
Apple Part Number: 655-1460D
MLC: DA2835
Thanks,
Dizi
 Post subject: Re: Wanted: Hitachi HTS723232L9SA6
PostPosted: May 15th, 2011, 2:56
I have same HDD and has crashed suddenly.
From what I've studied it seems that there is a problem with overheating.
Now I need to recover data on it.
Any help is welcome.
PostPosted: May 15th, 2011, 8:28
@sebim: For the type of help you are requesting, you are in the wrong part of this web forum :( - this section is the "Hard Drive Market" for buying & selling of parts.
If you want suggestions about recovery help, then you should start a new thread in the section here:
hard-disk-drives-data-recovery-and-repair-f1.html
FYI, when you start that new thread in the section above, you will need to give much more detail before anyone will be able to help you - for example:
- What exactly do you mean by "crashed"? Do not try to guess what has happened inside the disk and do not use "web jargon" - just describe the situation clearly and accurately. What symptoms do you see, exactly? What happened just before "the problem" started - anything unusual?
- Is this an internal or external drive?
- Any unusual smell or noises from the drive?
- Why do you believe that overheating is involved? You say that you have "studied" this, so please provide a link to the website(s) where you have seen this information and explain why you think those websites apply to your situation.
As I said before - you should not continue in this thread, because you are not buying/selling disk parts. Instead, if you want assistance related to recovery, start a new thread in the forum which I linked above. If you supply enough detail in that new thread, then perhaps you will receive some advice/suggestions. :)
