| WD6400AAKS-22A782 pcb needed http://forum.hddguru.com/viewtopic.php?f=15&t=19433 |
Page 1 of 1 |
| Author: | nydatapc [ May 17th, 2011, 12:28 ] |
| Post subject: | WD6400AAKS-22A782 pcb needed |
Hello. I need a replacement part for my WD6400AAKS-22A782. I can provide more info about the HDD if needed. The hdd powers up for 10-15 sec after it dies. I think that the PCB it's malfunction, and planing to do a hot swap using Data Compass. Any thoughts about it? I want to thank you in advance for your help. |
| Author: | drc [ May 17th, 2011, 12:41 ] |
| Post subject: | Re: WD6400AAKS-22A782 pcb needed |
nydatapc wrote: I think that the PCB it's malfunction Probably notnydatapc wrote: planing to do a hot swap using Data Compass. This doesn't make senseI suggest sending to a pro |
