WD2000JS-60NCB1
http://forum.hddguru.com/viewtopic.php?f=15&t=19740
Author:  zummano [ June 17th, 2011, 14:33 ]
Post subject:  WD2000JS-60NCB1
Hi
I'm looking for the WD2000JS-60NCB1 PCB.
These are the details of the HD:
File comment: HD
File comment: PCB
Thanks for any help
Author:  zummano [ June 19th, 2011, 22:45 ]
Post subject:  Re: WD2000JS-60NCB1
Just wanted to add the other side too.
Author:  Eric Lee [ June 20th, 2011, 9:19 ]
Hi, we have this working PCB in stock, pls contact my hotmail to see if I can help or not.
Thanks, Eric
Author:  pcimage [ June 21st, 2011, 7:10 ]
You have PM
Author:  fzabkar [ June 21st, 2011, 7:26 ]
You need to move the 8-pin serial flash memory chip at location U12 from patient to donor.
The following board supplier includes a "firmware" transfer service:
http://www.hdd-parts.com/20091010.html
BTW, the damage to your SMOOTH motor controller IC suggests that it would be advisable to verify the resistances of the motor windings.
