Looking for Samsung F3 PCB (HD103SJ)
http://forum.hddguru.com/viewtopic.php?f=15&t=19756
Author:  KStEaL [ June 19th, 2011, 19:40 ]
Post subject:  Looking for Samsung F3 PCB (HD103SJ)
Hi !
My HDD is dead cause i did touch it in operation.
My mother card doesn't reconize him anymore and does not spin.
This is his spec, but i don't know all of it
Model : HD103SJ
S/N : S246J1KZ203460
I bought it in Paris, 07/21/2010 (almost 1 year)
So :
What PCB must i buy to remplace mine (cause i don't know the spec i have to check, plz check the picture)
Chere can i buy it ?
Thanks you very much for your help.
PS: If you need more picture, just tell me
Author:  hdrescue [ June 20th, 2011, 8:06 ]
Post subject:  Re: Looking for Samsung F3 PCB (HD103SJ)
Hi
If you have a multimeter first of all check the diodes.
To match a pcb you need the same pcb letters and the close date possible.
You have a sticker covering the drive date.. tell us the date of this drive.
Author:  KStEaL [ June 20th, 2011, 13:51 ]
What do you mean in PCB letter ? The number on the main chip
(K4H561638J-LCCC) ? (cf picture number 5)
I have only one sticker on my HDD, you can see 46080.40 . Is your drive date you are talking about ?
Author:  fzabkar [ June 21st, 2011, 4:32 ]
The K4H561638J-LCCC chip is the SDRAM.
The "main" chip is the Marvell MCU, 88i9025-TFJ2.
The drive's manufacture date is under the 46080.40 sticker.
From an examination of the date codes on the various ICs, I would expect a manufacturing date of around January or February 2010.
BTW, hdrescue is asking you to check the TVS diodes:
http://www.users.on.net/~fzabkar/HDD/HD103SJ_TVS.jpg
Repost to the repair forum if you need more help in this regard. You may not need a PCB ...
Author:  KStEaL [ June 22nd, 2011, 16:24 ]
You're right , the production date under the sitcker is 2010.02
For the diode, i don't understand ? What do I have to check ? Cause i don't have a multimeter....
Author:  KStEaL [ June 22nd, 2011, 16:32 ]
To resume this is the specs ive to looking for :
Main chip : Marvell MCU, 88i9025-TFJ2
Production date : 02/2010 (close as possible)
Author:  fzabkar [ June 23rd, 2011, 15:54 ]
If you want to discuss your DIY repair options, then repost to the Repair forum:
hard-disk-drives-data-recovery-and-repair-f1.html
BTW, a digital multimeter should cost you less than US$10. In fact here is a DMM for $5:
Cen-Tech 90899 7 Function Digital Multimeter (US$5):
http://www.harborfreight.com/7-function ... 90899.html
Cen-Tech 90899 7 Function Digital Multimeter User Manual:
http://manuals.harborfreight.com/manual ... 90999/9089
Author:  KStEaL [ June 24th, 2011, 12:42 ]
A friend of mine will lend me one.
I will test the diode.
Is there a tuto somewhere ? Or must i post on repair section.
Author:  KStEaL [ July 2nd, 2011, 17:18 ]
OK, i will repost in the repair section,
Btw, is somebody sold the PCB , if i can't repair it ?
Author:  harddrivedonor [ February 15th, 2012, 4:13 ]
we have this pcb in stock and many more
http://pcb-hdd.com/samsung-hd103sj-p-524.html
Author:  hddzone [ January 30th, 2013, 23:53 ]
Samsung's donor PCB should have the same board number as the damaged board. The board number is etched on the PCB, begin with BF41-
