 Post subject: LF Hitachi PCB
PostPosted: July 8th, 2011, 9:43
I have a hitachi mobile hard drive that does nothing. I'm looking to change out the PCB and see if this helps the situation any. I have already replaced the drive with another so there is no rush to get this part. The drive's information is below.
Thank you,
Preston
Model# HTS541680J9SA00
P/N: 0A50538
(OEM: 433144-001)
MLC: DA1697
A225121
On the PCB are the numbers
0A50426
DA1550A
Xdn714
04AZ
 Post subject: Re: LF Hitachi PCB
PostPosted: July 8th, 2011, 12:10
Check the fuse at F1 first, if not I have a PCB (but you will need to swap the NVRAM chip)
PM me for pricing on PCB
PostPosted: July 8th, 2011, 13:26
OK thank you
Preston
PostPosted: July 11th, 2011, 5:28
Hi
I have a perfect match for the pcb you want.
Send you PM with the prices.
