Need PCB for Fujitsu MHT2060AT
http://forum.hddguru.com/viewtopic.php?f=15&t=20123
Author:  xkelly [ July 27th, 2011, 19:14 ]
Post subject:  Need PCB for Fujitsu MHT2060AT
Came out of a Dell Inspiron laptop that kept posting an error on boot. I think the motherboard died. When I yanked the drive to copy the data, I found it wouldn't power up. Hoping replacing the pcb will allow me to recover the data. PDF of current PCB is attached. Thanks.
Fujitsu MHT2060AT.pdf [133.56 KiB]
Downloaded 730 times
Author:  Eric Lee [ July 30th, 2011, 8:38 ]
Post subject:  Re: Need PCB for Fujitsu MHT2060AT
Hi, Pls send us clear photos of both side of your PCB so that we could match what you need.
Thanks, Eric.
Author:  xkelly [ July 31st, 2011, 19:25 ]
Thanks, Eric.
Here you go!
Thanks.
Fujitsu MHT2060AT PCB Front & Back.pdf [1.25 MiB]
Downloaded 551 times
Author:  Eric Lee [ August 3rd, 2011, 6:01 ]
Hi, Thanks for photo, we confirm that we have this working PCB in stock, pls contact my hotmail.
Thanks, Eric
Author:  Dima [ August 3rd, 2011, 10:01 ]
check the fuse?
it is situated on the right top hand.
Author:  xkelly [ August 3rd, 2011, 11:14 ]
Dima wrote:
check the fuse?
Dima- Didn't realize there was a fuse. Thanks for the heads-up.
I've posted a marked up picture. Is that the fuse outlined in red?
Where would I purchase one? I live in the US--New York.
Thanks.
Eric,
I want to check the fuse before I order a new PCB. I definitely let you know either way.
Fujitsu MHT2060AT PCB Fuse.pdf [348.43 KiB]
Downloaded 542 times
Author:  Avengence [ August 9th, 2011, 10:48 ]
That isn't the sort of thing you find in any shop you can walk into. Your best bet is digikey or mouser for surface mount parts.
However, as this is just a fuse, for the purposes of recovery I would just bypass it with a small wire. Of course, be sure you are bypassing the right part, shorting something else than the fuse could make the situation worse.
Author:  xkelly [ August 12th, 2011, 16:12 ]
So... just to update. I'm going to try and jump the fuse with a wire and see if the drive spins up. First I have to buy a strong magnifying glass. :-)
Thanks for everyone's help. I will keep you posted.
