PCB Needed for WD1600AAJS 2060-701590-000 REV A
Posted: August 17th, 2011, 17:29
Hi
I have a WD1600AAJS which promptly died on me and contains some very important data. After many tests I reached the conclusion it's the controller that's causing the problem (Linux reports the signal stuck at the buffer unable to get through), the disk spins up just fine and does not make any noise or anything to make me suspicious of the disk it self. My BIOS can see it but any OS is unable to use it.
So, I spoke to a friend who owns a lab and he said if I get him a working PCB he can change them no problem. Soooo anyone got one or can point me in the direction to get one?
Thanks a lot in advance, any help on this would be greatly appreciated.
BTW I saw on some other threads that you guys ask for pics so I went ahead and uploaded some ,let me know if it helps in any way.
