 Post subject: HDD PCB Needed Seagate 160GB
PostPosted: March 29th, 2011, 22:27
Seagate Barracuda 7200.7
160Gbytes
Model:ST3160021A
S/N:4JS0A4RC
P/N:9W2001-373
HDA P/N : 100316342'
Config: D11W-01
Firmware:8.01
Date Code:0544 Site Code:TK
Main Chip #: 100319396
Board #: 100282774
A PCB Matching These Specifications Or The Ones Listed Here:
http://www.onepcbsolution.com/seagate-b ... -2774.html
Thanks in advance heaps if you can help me.
 Post subject: Re: HDD PCB Needed Seagate 160GB
PostPosted: March 30th, 2011, 4:08
Can you describe the failure symptom?
One of us may be able to help you repair your board, or at least confirm that the problem isn't elsewhere.
PostPosted: March 30th, 2011, 19:29
It was being disconnected and reconnected from the pc randomly then when i pulled out the data cable it was smell of smoke plug back in and then it wouldnt read at all but still spin.
PostPosted: March 30th, 2011, 20:59
I can't understand why pulling out the data cable would cause the drive to smoke. It's quite possible that one or more signals on the IDE interface would have been damaged, though. I assume that you've switched IDE ports, just in case the motherboard was damaged as well as, or instead of, the drive.
PostPosted: March 31st, 2011, 2:34
Hi, I have this working PCB in stock, pls contact my hotmail.
Thanks, Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: April 11th, 2011, 3:29
i have this PCB in stock. still need? you can contact me by email or skype. would you like to show me images of your PCB that we may help you without order a PCB.
data recovery service[/b]
PostPosted: September 16th, 2011, 6:16
PCB Needed again if anybody has in stock willing to pay up to $40AUS .....
PostPosted: September 18th, 2011, 8:39
Thanks, Eric.
Users browsing this forum: No registered users and 117 guests
