 Post subject: Need a PCB for a Fujitsu 80gb hdd
PostPosted: October 10th, 2011, 1:34
I have a Fujitsu 80gb hdd
model:mhw2080bh pl
part no:ca06820-b39200ap
Number on PCB is: ca26343-b84304ba
I was wondering if anyone knew where I could find a PCB for my hdd.
My hdd is making a clicking sound and I figured I could try to swap out PCB and see if that will fix the problem.
 Post subject: Re: Need a PCB for a Fujitsu 80gb hdd
PostPosted: October 10th, 2011, 8:06
Your assumption is probably wrong.
If drive spins up and clicks, then most probably there is absolutely no problem with your pcb.
Clicking could mean bad heads or some other problem like corrupted firmware.
Both these are not DIY and you should consider sending disk to a pro in your area.
If data is important, that is.
