 Post subject: NEED: PCB WD5000AAKS-75TMA0, 2061-701477-800 AC
PostPosted: October 11th, 2011, 23:58
need a pcb asap.
fried it.
dets:
WD5000AAKS-75TMA0
date: 03 May 2007
DCM: HHRCHV2CHB
Drive Parameters
LBA 976773168
pcb says : 2061-701477-800 AC
I dont know what other info is needed!
not a pro! xD
 Post subject: Re: NEED: PCB WD5000AAKS-75TMA0, 2061-701477-800 AC
PostPosted: October 12th, 2011, 1:29
Hi, We have this working PCB in stock. Pls contact my hotmail.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: October 12th, 2011, 10:42
thanks! emailed.
PostPosted: October 12th, 2011, 10:56
Im not sure how to edit original posts, but if ppl need more info
2060-701477-001 REV A
PostPosted: October 13th, 2011, 3:30
A PCB will be useless unless your supplier transfers the "adaptive" data from your original board to your replacement. Moreover, if your original board is damaged, then your supplier probably won't have the ability to extract the needed data.
In short, you will be wasting your money on a replacement board.
If you need help in assessing the damage, then repost to the Repair forum.
