Wanted: WD 2061-701453-A00 AC PCB
http://forum.hddguru.com/viewtopic.php?f=15&t=20832
Author:  molcos [ October 16th, 2011, 8:06 ]
Post subject:  Wanted: WD 2061-701453-A00 AC PCB
Hello.
My WD Raptor [WD1500AHFD-00RAR1] has a burnt PCB and needs a replacement.
Been looking for a replacement board but found none so far.
Initially i thought that i could just buy a similar HDD and replace the board, but i later learnt that it wasn't that easy.
I would be very happy if someone had a functional PCB for me.
The drive is manufactured in Malaysia.
Regards Marcus
Author:  pcimage [ October 16th, 2011, 9:13 ]
Post subject:  Re: Wanted: WD 2061-701453-A00 AC PCB
What's the part number of the board?
Author:  molcos [ October 16th, 2011, 10:02 ]
The only numbers i can see on the drive is these.
S/N: WMAP41524446
MDL: WD1500AHFD-00RAR1
Number etched on the PCB: 2060-701453-000 REV A
Number on the Plastic IDE/power connector: 2061-701453-A00 AC
Author:  pcimage [ October 16th, 2011, 11:02 ]
Sorry, I did not see the part number in the message title :oops:
I will check tomorrow if I have that PCB.
Author:  molcos [ October 16th, 2011, 12:20 ]
Perfect, thanks for the help :)
Author:  pcimage [ October 17th, 2011, 8:12 ]
You have PM
Author:  jaouahire [ October 25th, 2011, 4:47 ]
Hi
I have a PCB with this ref: 2061 - 701453 - A00 AC. It's from a hd WD360ADFD
