 Post subject: recover data from undetected hard disk in bios
PostPosted: October 23rd, 2011, 16:45
any one help please and please i have watching movie in my pc and immediately system hang with continous beap , then after bios does not detect any device,not pri,not seco,not master,not slave ,,,.
All options are None.
If my HARDDISK IS DAMAGE THEN PLEASE GIVE ME SEGGESTION FOR RECOVER MY IMPORTANT DATA FROM HD
MY HD IS 500 GB SEAGATE SATA
If required in this process any other hard disk then i will purchase another hd Please any one help me .
1.If any one known linux recuse data recovery then say about tìs
2:_Simply hd is not detected by bios neither primary nor secondary
3:_by which way we can recover data please please please...thanks in advanceeeeeeee......
 Post subject: Re: recover data from undetected hard disk in bios
PostPosted: October 23rd, 2011, 19:48
You have to be more descriptive about the hdd. It's like saying "my car is not working. Can someone help me fix it?"
1. What does the hdd do exactly as far as sounds? Put your ear close to it and listen for odd sounds.
2. Does the hdd show up in BIOS with correct model and capacity?
PostPosted: October 24th, 2011, 6:37
..adding to labtech's questions:
3. Are there any other hdd's connected to your machine. Because you say
If you have more hdds on machine and none of them are detected, then there could be something wrong with your machine and not the hdd.
4. What is exact model of hdd?
