| Western Digital WD1200 http://forum.hddguru.com/viewtopic.php?f=15&t=21830 |
Page 1 of 1 |
| Author: | saruoz [ January 23rd, 2012, 23:36 ] |
| Post subject: | Western Digital WD1200 |
Hi Accidently plugged power supply backwards to hard drive input. MDL:WD1200JD-75FYBO DATE: 29 Aug 2003 DCM: DSCHCVJAH Thanks! |
| Author: | saruoz [ January 23rd, 2012, 23:55 ] |
| Post subject: | Re: Western Digital WD1200 |
More info from HDD PCB Sticker 2061-001215-200 AE 2060-001215-002 REV A |
| Author: | poehere [ January 24th, 2012, 13:30 ] |
Not only a replaement board can help you on this one. You need to move adaptive to the new board and if you burned more than the board there can be internal damage. Lots of time the premap is burned too. You would have to test this becasue if you put on new board it will burn too. |
| Author: | fzabkar [ January 24th, 2012, 17:45 ] |
Is there a chip at location U12? If you want help with repair, then repost your question to the repair forum. -Franc |
| Author: | saruoz [ January 24th, 2012, 21:38 ] |
There is a chip at U12. I'm guessing this is the ROM chip to be swapped to the new board? |
| Author: | pcimage [ January 25th, 2012, 3:00 ] |
saruoz wrote: There is a chip at U12. I'm guessing this is the ROM chip to be swapped to the new board? Yes. |
| Author: | saruoz [ January 25th, 2012, 21:29 ] |
| Post subject: | Harddrivespecialist |
Hey Harddrivespecialist can yu PM me your phone #. I cant send Pm's for some reason maybe too new to forum. THANKS |
