 Post subject: Western Digital WD1200
PostPosted: January 23rd, 2012, 23:36
Hi
Accidently plugged power supply backwards to hard drive input. :( Removed PCB from hard drive and there are no signs of physical damage however hard drive does not respond. Looking for replacement board for WD1200 Caviar Serial ATA
MDL:WD1200JD-75FYBO
DATE: 29 Aug 2003
DCM: DSCHCVJAH
Thanks!
 Post subject: Re: Western Digital WD1200
PostPosted: January 23rd, 2012, 23:55
More info from HDD
PCB Sticker 2061-001215-200 AE
2060-001215-002 REV A
PostPosted: January 24th, 2012, 13:30
Not only a replaement board can help you on this one. You need to move adaptive to the new board and if you burned more than the board there can be internal damage. Lots of time the premap is burned too. You would have to test this becasue if you put on new board it will burn too.
Iorana Haraharaini
PostPosted: January 24th, 2012, 17:45
Is there a chip at location U12?
If you want help with repair, then repost your question to the repair forum.
-Franc
PostPosted: January 24th, 2012, 21:38
There is a chip at U12. I'm guessing this is the ROM chip to be swapped to the new board?
PostPosted: January 25th, 2012, 3:00
Yes.
 Post subject: Harddrivespecialist
PostPosted: January 25th, 2012, 21:29
Hey Harddrivespecialist can yu PM me your phone #. I cant send Pm's for some reason maybe too new to forum.
THANKS
