 Post subject: Need PCB 2060-70537-003 Rev A for WD1600AAJS-00B4A0
PostPosted: March 23rd, 2012, 16:37
Hi all:
I need PCB 2060-70537-003 Rev A for WD1600AAJS-00B4A0.
My server power supply burned up, taking every drive in the chassis with it. PCB's have a hole burned through them.
I'd like to attempt replacing the PCB on one of them before I try any disaster recovery companies.
MDL:WD1600AAJS-00B4A0
Date:07 Jul 2008
DCM:DARNNT2AA
R/N:701537
LBA 312581808
I found a reference in a Western Digital support response that said as long as the model, LBA, and last 3 digits of DCM are identical then replacement is an option.
I thought I'd try here first.
Thanks!
Shock
 Post subject: Re: Need PCB 2060-70537-003 Rev A for WD1600AAJS-00B4A0
PostPosted: March 24th, 2012, 1:35
This drive requires programming the new pcb this has to be done with special tools so even if u find a compatible pcb it will not work with your drive until you program it .
You should find a pro neat you .
PostPosted: March 24th, 2012, 23:09
Could we see a photo of the damage? It may be that the damage is not confined to the PCB.
Otherwise, if you are willing to spend US$150 on a software tool (WDR-UDMA or WD HD Pro), then you may have a chance at a DIY repair.
PostPosted: March 26th, 2012, 13:16
Here is the PCB. Burn mark is on the 2nd largest chip in the top right corner. The burn does not go through to the reverse side of the board.
I've been told that I can replace the PCB with a matching PCB but I would have to move the large chip in the center over to the new board.
That chip does not seem to have any solder points. Does anyone know how to remove it without damage?
Here is the picture of the board. This site restricts pics to 1024 pixels, so selecting the URL should show the board in it's full resolution:
http://sw-air.com/IMG_20120326_081012.jpg
PostPosted: March 27th, 2012, 3:07
The SMOOTH chip controls the onboard power supplies. Unfortunately it appears to be damaged on the side that controls the Vcore regulator for the Marvell MCU (88i8845C-BHG2). If the MCU is damaged, then there will be no point trying to transfer it.
You might like to follow up this thread:
professional-hard-drive-and-pcb-supplier-over-10k-drives-t22122.html
PostPosted: March 27th, 2012, 3:12
Hi, we have this working PCB in stock, however, for this kinds of PCB, it is little hard to manage by personal. pls contact my hotmail.
Thanks, Eric.
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
Users browsing this forum: No registered users and 86 guests
