| Looking for Hitachi 2.5" 500GB (HTS547550A9E384) http://forum.hddguru.com/viewtopic.php?f=15&t=22822 |
Page 1 of 1 |
| Author: | DanR [ May 2nd, 2012, 7:22 ] |
| Post subject: | Looking for Hitachi 2.5" 500GB (HTS547550A9E384) |
Hi guys, I'm looking for a donor drive. HTS5475509E384 HDD : 5k750-500 P/N : H2T500854S MLC : DA4124 First two lines of PCB : 0J11457 DA3743A What matching criteria should I be looking for if wish to replace the HSA? Part Number AND PCB? Thanks, -DR |
| Author: | loki [ May 2nd, 2012, 7:43 ] |
| Post subject: | Re: Looking for Hitachi 2.5" 500GB (HTS547550A9E384) |
DanR wrote: Hi guys, I'm looking for a donor drive. HTS5475509E384 HDD : 5k750-500 P/N : H2T500854S MLC : DA4124 First two lines of PCB : 0J11457 DA3743A What matching criteria should I be looking for if wish to replace the HSA? Part Number AND PCB? Thanks, -DR http://www.donordrives.com/hard-drive-p ... swap-match Hitachi / IBM.PCB Match Criteria (for logic board replacement). ROM / NV-RAM Chip Transfer Required. 8-pin chip. 1. Full Model Number. Example: HTS541040G9AT00, IC25N040ATMR04-0 2. First 2 lines of PCB white sticker. Example: 0A54296 DA1803A, 0A71339 BA3293_ Hard Drive Match Criteria (for Head Stack Assembly replacement or Platter Swap) 1. Full Model Number. Example: HTS541040G9AT00, IC25N040ATMR04-0 2. Part Number. Example: 0F10311, 0A30243 3. MLC. Example: BA1116, DA2010 |
