 Post subject: WTB (NEED to buy) WD2500KS-00MJB0, DCM: DSCANTJAA
PostPosted: July 19th, 2012, 22:34
Hi, I'm looking for a hard drive (or just PCB) with these exact specs. I know it's a long shot, but worth a try:
Western Digital WD2500KS (Caviar SE16)
Model WD2500KS-00MJB0
DCM: DSCANTJAA (important, so I can use the U12 chip and not have to transplant it -- we just tried that here and we think the electrician burned the chip because now it won't spin up at all)
LBA 488397168
Please let me know if you have this or know where I can buy it. I've come close on google, but no matches yet for the same model + DCM. I've gotten close; found one with DCM # DSCANT2AA, but not DSCANTJAA.
Thanks! :D
 Post subject: Re: WTB (NEED to buy) WD2500KS-00MJB0, DCM: DSCANTJAA
PostPosted: July 20th, 2012, 1:21
Have you tried Eric Lee......?
http://www.eadr.co.uk
PostPosted: July 20th, 2012, 8:19
+1 for Eric
Also try dronordrives.com
Here's the custom Google search for Hard Drive Parts Suppliers which has been posted on this forum before.
http://www.google.com/cse/home?cx=01186 ... vt8_adlkk4
PostPosted: July 20th, 2012, 13:38
The DCM probably won't help you to be honest.
You may get lucky, but ideally you need pro assistance.
I wish you all the best of luck.
PostPosted: July 21st, 2012, 13:31
We have 5 of this model stock. None of which have this exact DCM. Please advise if you still require this model and we can direct you to our site so you can see exactly what we have. All of our drives are listed with exact details including the PCB numbers. Brett
Effective Electronics, LLC
Ph: 407-463-0699
Fax: 407-264-6714
effectelec@aol.com
