 Post subject: Wanted: PCB for ST1000LM010
PostPosted: August 27th, 2012, 22:05
Looking for a replacement PCB for a Seagate FreePlay ST1000LM010 hard drive PN 9YH146-550, FW CC9E. PCB IC LSI 866508 SEAGATE 1039T TPP3K923 23MM001FQHF 8AM391CT. Small chip 980 L SH6966 A 07A1XLID.
Anyone?
 Post subject: Re: Wanted: PCB for ST1000LM010
PostPosted: September 4th, 2012, 8:30
Hello managerharry
if you google `ST1000LM010 cc9f pcb` there is many to shops offering it.
PostPosted: September 4th, 2012, 18:49
I have seen those listings but this drive has FW CC9E, I am assuming the FW should match. Is that incorrect?
PostPosted: September 5th, 2012, 3:14
It doesn't matter, a straight PCB swap will NEVER work on this model.
You WILL need to transfer the ROM chip, it is absolutely UNIQUE to the drive, even the S/N of the drive is programmed into this ROM!
PostPosted: September 5th, 2012, 3:25
Negative. f/w doesn't matter.
Match the 100******* . then transfer the ROM
Edit: Sean beat me to it.
PostPosted: September 5th, 2012, 15:16
PostPosted: October 23rd, 2012, 5:52
You WILL need to transfer the ROM chip.
http://www.hddzone.com - Buy HDD PCB Boards for Data Recovery Needs! Worldwide Free Shipping.
PostPosted: December 9th, 2012, 8:15
can any one supply me with the firmware ?
thanks
