| Wanted: PCB for ST1000LM010 http://forum.hddguru.com/viewtopic.php?f=15&t=23840 |
Page 1 of 1 |
| Author: | managerharry [ August 27th, 2012, 22:05 ] |
| Post subject: | Wanted: PCB for ST1000LM010 |
Looking for a replacement PCB for a Seagate FreePlay ST1000LM010 hard drive PN 9YH146-550, FW CC9E. PCB IC LSI 866508 SEAGATE 1039T TPP3K923 23MM001FQHF 8AM391CT. Small chip 980 L SH6966 A 07A1XLID. Anyone? |
| Author: | DRforensic [ September 4th, 2012, 8:30 ] |
| Post subject: | Re: Wanted: PCB for ST1000LM010 |
Hello managerharry if you google `ST1000LM010 cc9f pcb` there is many to shops offering it. |
| Author: | managerharry [ September 4th, 2012, 18:49 ] |
I have seen those listings but this drive has FW CC9E, I am assuming the FW should match. Is that incorrect? |
| Author: | pcimage [ September 5th, 2012, 3:14 ] |
managerharry wrote: I have seen those listings but this drive has FW CC9E, I am assuming the FW should match. Is that incorrect? It doesn't matter, a straight PCB swap will NEVER work on this model. You WILL need to transfer the ROM chip, it is absolutely UNIQUE to the drive, even the S/N of the drive is programmed into this ROM! |
| Author: | northwind [ September 5th, 2012, 3:25 ] |
Negative. f/w doesn't matter. Match the 100******* . then transfer the ROM Edit: Sean beat me to it. |
| Author: | pcimage [ September 5th, 2012, 15:16 ] |
northwind wrote: Negative. f/w doesn't matter. Match the 100******* . then transfer the ROM Edit: Sean beat me to it. |
| Author: | tomsfans [ October 23rd, 2012, 5:52 ] |
You WILL need to transfer the ROM chip. |
| Author: | zjor2000 [ December 9th, 2012, 8:15 ] |
can any one supply me with the firmware ? thanks |
