 Post subject: Looking for working WD1200BEVS - 07LAT0
PostPosted: October 20th, 2012, 10:12
Have a 120GB 2,5" WD drive, which was dropped and wil lnot start.
Additional drive data:
Date: 03 NOV 2006
DCM: HCTJHNB
s/n: WXE06079751
Need a replacement.
Thanks for assistance!
andter @ gmail com
A
 Post subject: Re: Looking for working WD1200BEVS - 07LAT0
PostPosted: October 20th, 2012, 12:12
Couple of things:
1) "Does not start" means exactly what?
2) "Need a replacement" means what?
PostPosted: October 20th, 2012, 12:36
1) Shows no signs of "powering up"
2) A company which is repairing said "needs a donor HDD". Hence, basically I need identical HDD.
Thanks!
PostPosted: October 20th, 2012, 12:51
andter wrote:
1) Shows no signs of "powering up" <<< poor/strange explanation
2) A company which is repairing said "needs a donor HDD". Hence, basically I need identical HDD. <<<not a good sign if company asks you to do this
Thanks!
http://www.donordrives.com/western-digi ... -6826.html
Best wishes
PostPosted: October 20th, 2012, 12:59
Thanks..
However, I need identical 07LAT0 with HCTJHNB (pics below)
They said they have tried already with similar ones. System finds a disk, but it does not represent data.
Thanks!
File comment: Needed drive
PostPosted: October 20th, 2012, 13:06
Chances of finding identical model and DCM are slim to none.
Since it seems you do not know much know about the donor requirements, thus the request seems to basically come from the company, it is definitely an indicator they do not know what they are doing.
PostPosted: October 21st, 2012, 11:31
Agree with Labtech, sounds like these guys don't have a clue :-
Also "system finds a disk, but does not represent data" sounds a bit strange, vague at best.
PostPosted: October 22nd, 2012, 9:48
+2, these guys can't tell an arse from elbow.
PostPosted: October 23rd, 2012, 5:42
Need a replacement?
PostPosted: October 23rd, 2012, 9:44
thanks for help all.
Just to make it more clearer: There is a need for an identical HDD.
PostPosted: October 23rd, 2012, 10:12
You don't need an IDENTICAL drive, like you've been told.
You need to match *some* of the things but not all.
That's why we suggest someone else to have a look at your drive.
PostPosted: October 23rd, 2012, 10:34
For your own good, even if you find an identical donor let's say, chances are that your drive will still not work as there are certain adaptives that would prevent that from happening.
Spend some time on the forum here reading and you will see...
