WANTED: A PCB/Board for a Seagate Barracuda 7200.11
http://forum.hddguru.com/viewtopic.php?f=15&t=23938
Author:  bossmanmg [ September 8th, 2012, 18:26 ]
Post subject:  WANTED: A PCB/Board for a Seagate Barracuda 7200.11
Need a board/pcb for a Seagate Hard Drive I have.
NEEDS TO BE ABLE TO MATCH THE ONE I HAVE!!!!
INFO ON MOTHERBOARD:
100512585 F M9164H0A
INFO ON HARD DRIVE:
S/N: 5TE0B7P9
ST 31000333AS
P/N: 9FZ136-568
FIRMWARE: SD35
DATE CODE: 09214
SITE CODE: SU
IF YOU HAVE A BOARD/PCB THAT IS IN WORKING CONDITION PLEASE CONTACT ME. I DO NOT NEED THE WHOLE HARD DRIVE JUST THE BOARD. THANK YOU!
Author:  labtech [ September 8th, 2012, 19:43 ]
Post subject:  Re: WANTED: A PCB/Board for a Seagate Barracuda 7200.11
Typically, these drives do not have PCB issues. Are you sure it is a PCB issue?
Author:  DRforensic [ September 10th, 2012, 17:14 ]
http://pcb-hdd.com/st31000333as-sd35-10 ... -1646.html
Author:  Eric Lee [ September 12th, 2012, 8:42 ]
Hi, we have this working PCB, pls contact my hotmail.
Thanks, Eric
Author:  hddzone [ February 26th, 2013, 0:11 ]
The PCB's donor PCB should have same board number - 100512588 as yours. When you get this PCB, you need move your original PCB's BIOS to the replacement PCB. The 8pins (4 pins on each sides) with 25P05VP、25P10VP、25F512、25F1024、25F1024AN、SST25VF512、SST25VF010, etc. are the BIOS.
Author:  northwind [ February 26th, 2013, 4:36 ]
what's with the knife?
