 Post subject: WANTED: A PCB/Board for a Seagate Barracuda 7200.11
PostPosted: September 8th, 2012, 18:26
Need a board/pcb for a Seagate Hard Drive I have.
NEEDS TO BE ABLE TO MATCH THE ONE I HAVE!!!!
INFO ON MOTHERBOARD:
100512585 F M9164H0A
INFO ON HARD DRIVE:
S/N: 5TE0B7P9
ST 31000333AS
P/N: 9FZ136-568
FIRMWARE: SD35
DATE CODE: 09214
SITE CODE: SU
IF YOU HAVE A BOARD/PCB THAT IS IN WORKING CONDITION PLEASE CONTACT ME. I DO NOT NEED THE WHOLE HARD DRIVE JUST THE BOARD. THANK YOU!
 Post subject: Re: WANTED: A PCB/Board for a Seagate Barracuda 7200.11
PostPosted: September 8th, 2012, 19:43
Typically, these drives do not have PCB issues. Are you sure it is a PCB issue?
PostPosted: September 10th, 2012, 17:14
http://pcb-hdd.com/st31000333as-sd35-10 ... -1646.html
PostPosted: September 12th, 2012, 8:42
Hi, we have this working PCB, pls contact my hotmail.
Thanks, Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: February 26th, 2013, 0:11
The PCB's donor PCB should have same board number - 100512588 as yours. When you get this PCB, you need move your original PCB's BIOS to the replacement PCB. The 8pins (4 pins on each sides) with 25P05VP、25P10VP、25F512、25F1024、25F1024AN、SST25VF512、SST25VF010, etc. are the BIOS.
http://www.hddzone.com - Buy HDD PCB Boards for Data Recovery Needs! Worldwide Free Shipping.
PostPosted: February 26th, 2013, 4:36
what's with the knife?
