WD10EARX-00N0YB0
http://forum.hddguru.com/viewtopic.php?f=15&t=26651
Author:  dmarques [ August 16th, 2013, 4:50 ]
Post subject:  WD10EARX-00N0YB0
I need one of these drives, but need a head map 0, 1, 2.
Anyone can check this please.
Btw, this is WD Sadle2D family.
Author:  HardDrivesForSale [ August 16th, 2013, 15:58 ]
Post subject:  Re: WD10EARX-00N0YB0
We do have this hard drive:
MDL: WD10EARX-00N0YB0
S/N: WMC0S0493733
Date: 02 MAR 2012
DCM: EBRCNV2MBB
2060-771698-004 REV A on the PCB
2061-771698-904 AE on the barcode sticker
http://www.harddrivesforsale.com/wd10earx-00n0yb0.html
Please let us know if this will work for you, we can provide you with head map.
Author:  lcoughey [ August 16th, 2013, 16:15 ]
I noticed that you did not confirm the head map, which the OP requested. Can you confirm that your donor has the head map 0,1,2?
Author:  HardDrivesForSale [ August 16th, 2013, 17:09 ]
Our technician just checked it and it is head map is 0,1,3.
S/N: WMC0S0493733
However we found hard drive with same head map requested. Here is specs:
S/N: WMC0T0483067
Date: 01 MAR 2012
DCM: HBRNHT2MBB
http://www.harddrivesforsale.com/wd10ea ... yb0-1.html
Head map here is 0,1,2
Please let us know if you have any questions.
Author:  Starling [ August 27th, 2013, 16:56 ]
http://mydonordrives.com/ViewDrive/496
