WANTED HDD Fujitsu MHZ2500BT G1
http://forum.hddguru.com/viewtopic.php?f=15&t=26841
Author:  halski [ September 7th, 2013, 6:52 ]
Post subject:  WANTED HDD Fujitsu MHZ2500BT G1
as in the subject wanted hdd:
exact model is: MHZ2500BT G1
part no: CA06900-B41100SN
pcb (board print no): CA21344-B61X
if you have same pcb or heads for this drive contact me on priv pls
Author:  HardDrivesForSale [ September 9th, 2013, 15:32 ]
Post subject:  Re: WANTED HDD Fujitsu MHZ2500BT G1
We have the hard drive with the same model number, but other specification is not an exact match. You can check it on our website.
Thank you
