 Post subject: Looking for WD10JMVW-11S5XS0
PostPosted: August 27th, 2014, 10:02
Hello everyone,
I am looking for the following disk:
WD10JMVW-11S5XS0
DCM : SHMTJHK
date : 21/02/2013
country : malaysia
Thanks!
Marcus
 Post subject: Re: Looking for WD10JMVW-11S5XS0
PostPosted: August 28th, 2014, 14:59
Please see the following link for a compatible donor: http://www.donordrives.com/western-digi ... 26461.html
Heather Gray / Sales Specialist
Direct Line: 440-249-0638
Donor Drives LLC: (800) 733-0978 x204
PostPosted: August 28th, 2014, 19:04
We have more than one hard drive with similar specifications, here is one of them:
Model number: WD10JMVW-11S5XS0
Serial number: WX61EB2AE038
Date: 27 AUG 2013
DCM: EBMTJHB
2060-771801-002 REV A on the PCB
2061-771801-002 AE on the barcode sticker
SKU: 23097
http://www.harddrivesforsale.com/wd10jm ... xs0-2.html
Hard Drives For Sale
Largest hard drive supplier for data recovery purposes
More than 10,000 hard drives in stock and ready to ship
PostPosted: September 1st, 2014, 11:25
Hi!
Thanks for your answer. Besides DCM hhovjhn, I've seen you also have got disks with same model and the following DCM: EBMTJBK, HCMTJBK, EBMTJHN which seem closer to mine (SHMTJHK). Which one do you think will work best?
Marcus
PostPosted: September 2nd, 2014, 21:30
Marcus,
Usually data recovery companies try to match two letters in DCM, which in your case are "TJ", also closest date and country of Manufacturer, but it really depends on what methods and equipment you use.
PostPosted: September 3rd, 2014, 0:13
See http://www.deepspar.com/blog/Donor-Drive.html
... taking Western Digital drives as an example, several vendor-specific parameters located in the ROM and RAM of the drive help in finding a donor with better compatibility:
    Head map
    Microjog adaptives
    Drive information table
    Firmware release
Unfortunately, none of these parameters are located on a drive’s label. However, you can retrieve them using some data recovery tools.
An HDD Oracle forum member has written a tool to extract important donor matching data from MOD 47.
See http://malthus.zapto.org/viewtopic.php?f=59&t=1009
MOD 0A and MOD 0D contain "DCM", head map and firmware version information, including head and media type.
If you could upload your drive's ROM, then we could extract the relevant data.
PostPosted: September 3rd, 2014, 8:35
Hi HardDrivesForSale and fzabkar,
Thanks a lot for your answers!
