| Wanted - WDC Complete HDD 1TB Blue WD10EZEX-00RKKA0 http://forum.hddguru.com/viewtopic.php?f=15&t=31249 |
Page 1 of 1 |
| Author: | Amarbir[CDR-Labs] [ May 22nd, 2015, 9:17 ] |
| Post subject: | Wanted - WDC Complete HDD 1TB Blue WD10EZEX-00RKKA0 |
Hello , Need Quotes For Western Digital SATA 3.5" Blue 1TB HDD .MDL No is WD10EZEX-00RKKA0 .I need Complete Working HDD Picture of Required HDD
| Author: | northwind [ May 22nd, 2015, 10:19 ] |
| Post subject: | Re: Wanted - WDC Complete HDD 1TB Blue WD10EZEX-00RKKA0 |
Wow, a Tressels. Very rare. Cheaper I found was at $150, but I think you can use **M2N** which is quite cheaper. It should be compatible, with some modification at least. |
| Author: | Amarbir[CDR-Labs] [ May 22nd, 2015, 12:21 ] |
northwind wrote: Wow, a Tressels. Very rare. Cheaper I found was at $150, but I think you can use **M2N** which is quite cheaper. It should be compatible, with some modification at least. Northwind Sir , Is there focus on 3rd,4th and 5th digit in this or just 3rd and 4th . |
| Author: | northwind [ May 25th, 2015, 4:29 ] |
As far as I know, these aren't DCM sensitive. |
| Author: | northwind [ May 25th, 2015, 4:31 ] |
Or you mean on the model? 3rd 4th and 5th digit gives the model and the family. I don't know what you mean. |
| Author: | Amarbir[CDR-Labs] [ May 25th, 2015, 13:16 ] |
northwind wrote: Or you mean on the model? 3rd 4th and 5th digit gives the model and the family. I don't know what you mean. Well, i have been focussing on only 3rd and 4th digital i thing even the 5th is important and many family have 3 digit codes |
