Wanted - Western Digital 1TB Donor Drive
Posted: August 8th, 2015, 20:16
by Markf25
to try and recover my data quicker I'm helping my DR company look for:
WD 1.0TB USB3.0 Drive
MDL: WD10JMVW-xxS5Xxx
DCM: EHCTJBNB
DATE: 21 OCT 2012
Regards,
MF
Re: Wanted - Western Digital 1TB Donor Drive
Posted: August 8th, 2015, 23:42
by jermy
some details are missing like country of manufacture, head map, preamp rev.
Posted: August 9th, 2015, 0:12
by Markf25
Ok I'll ask the data recovery service for that information
Posted: August 9th, 2015, 0:28
by Markf25
Posted: August 12th, 2015, 2:57
by Markf25
jermy,
I've spoken to the data recovery service and they don't want to power it up as this may cause irreparable damage. They did so however that as it is a 1TB capacity it uses all heads.
Not withstanding the above, can you help with a donor drive ?
MF
Posted: August 12th, 2015, 5:42
by chinopk
i would suggest to let company search the donor, i think this is what they want. these passport drives are friendly for HSA compatibility so should not be a big deal.
Posted: August 12th, 2015, 6:30
by jermy
Markf25 wrote:I've spoken to the data recovery service and they don't want to power it up as this may cause irreparable damage.
no need to power the drive for that, it can be done by reading the ROM with PCB only (Boot ROM mode), or using an external programmer
Markf25 wrote:They did so however that as it is a 1TB capacity it uses all heads.
what about preamp rev ?
Markf25 wrote:can you help with a donor drive ?
ask them a copy of ROM (as explained above (PCB only or using an external programmer)) upload here, and i'll try my best.
Posted: August 12th, 2015, 6:51
by jermy
edit: what about the country of manufacture
