HDD GURU FORUMS
http://forum.hddguru.com/
Wanted Repair: netac U207 flashdrive firmware fix
http://forum.hddguru.com/viewtopic.php?f=15&t=32035
Page 1 of 1
Author:  etsteve [ October 2nd, 2015, 9:48 ]
Post subject:  Wanted Repair: netac U207 flashdrive firmware fix
Hello:
Netac Onlydisk pendrive with switch to select between floppy and hdd mode. Stopped working after hot removal.
Finally found a tool that work, u208 repair tool from usbdev.ru.
The problem is, the switch now works as write protect switch.
Request: Repair drive by sending me repair tool or loading correct firmware for U207.
Marking on chip is NT2039 old vid 0dd8 pid 14d8 taken from Usbdeview.
I can connect a laptop with win98, xp, 7 or linux for remote repair.
Best Regards
http://www.phpbb.com/
