Buy/sell hard drives, parts, tools
WD400BD-75LRA0
October 23rd, 2015, 17:14
I'm looking for a
WD400BD-75LRA0
DSBACVJCH
05JUL2005
MALAYSIA
Drive has only 1 Heads
All I have been able to find the head map is H1 and I need H0
Thank you in advance
Re: WD400BD-75LRA0
October 23rd, 2015, 17:28
Try looking for a 80gb model, that will have two heads. :-)
Re: WD400BD-75LRA0
October 23rd, 2015, 17:53
Two heads are better than one....
Re: WD400BD-75LRA0
October 26th, 2015, 10:56
I already tried with 80GB same DCM and close DCM still drive does not init....
Re: WD400BD-75LRA0
October 26th, 2015, 11:46
hdd_sand wrote:I already tried with 80GB same DCM and close DCM still drive does not init....
Well,
The 80GB Has Two Heads So Disable The Head You Do Not Want And enable Only The Head You Like .It Should Work .Take Some Advice From Senior Techs Around On The Forums ,Please Repost in Proper Location Again Not Market Section if You Like To Continue This Discussion
Re: WD400BD-75LRA0
October 26th, 2015, 12:24
Amarbir wrote:So Disable The Head You Do Not Want And enable Only The Head You Like
Cpt Obvious....
I posted on the right location, I'm looking for a donor not for advice. Thanks
