WD400BD-75LRA0
http://forum.hddguru.com/viewtopic.php?f=15&t=32167
Author:  hdd_sand [ October 23rd, 2015, 17:14 ]
Post subject:  WD400BD-75LRA0
I'm looking for a
WD400BD-75LRA0
DSBACVJCH
05JUL2005
MALAYSIA
Drive has only 1 Heads
All I have been able to find the head map is H1 and I need H0
Thank you in advance
Author:  pcimage [ October 23rd, 2015, 17:28 ]
Post subject:  Re: WD400BD-75LRA0
Try looking for a 80gb model, that will have two heads. :-)
Author:  thatdellguy [ October 23rd, 2015, 17:53 ]
Two heads are better than one....
Author:  hdd_sand [ October 26th, 2015, 10:56 ]
I already tried with 80GB same DCM and close DCM still drive does not init....
Author:  Amarbir[CDR-Labs] [ October 26th, 2015, 11:46 ]
Well,
The 80GB Has Two Heads So Disable The Head You Do Not Want And enable Only The Head You Like .It Should Work .Take Some Advice From Senior Techs Around On The Forums ,Please Repost in Proper Location Again Not Market Section if You Like To Continue This Discussion
Author:  hdd_sand [ October 26th, 2015, 12:24 ]
Cpt Obvious....
I posted on the right location, I'm looking for a donor not for advice. Thanks
