Donor needed, WD5000BMVW-11S5XS0
http://forum.hddguru.com/viewtopic.php?f=15&t=32313
Author:  Arik.Gart [ November 15th, 2015, 4:52 ]
Post subject:  Donor needed, WD5000BMVW-11S5XS0
Hello friends,
We need a donor drive for a recover case.
The donor must be compatibility with the below:
- WD5000BMVW-11S5XS0
- Head map: 1, 2, 3
- Heads number: 3
- Heads number in use: 3
- Rom firmware ver: 00030052
I attached the drive photo.
If it's perfectly fit to this parameters, Please PM an quote with FED-EX\UPS shipping to Israel.
Thanks.
Author:  MindMergepk [ November 15th, 2015, 8:44 ]
Post subject:  Re: Donor needed, WD5000BMVW-11S5XS0
here is perfect match.
good luck.
http://www.donordrives.com/western-digi ... 33581.html
Author:  Arik.Gart [ November 15th, 2015, 10:32 ]
MindMergepk wrote:
Thank you buddy :)
Author:  HardDrivesForSale [ November 16th, 2015, 20:38 ]
Here is a match if you are still interested
Model number: WD5000BMVW-11S5XS0
Serial number: WXF1CC1F3330
Date: 01 APR 2012
DCM: HHOVJBB
Product of Malaysia
2060-771801-002 REV A on the PCB
2061-771801-002 AB on the barcode sticker
WD Passport USB 3.0
Head map: 1 2 3
SKU 22514
https://www.harddrivesforsale.com/wd500 ... xs0-3.html
