 Post subject: PORTABLE CLEAN ROOM
PostPosted: May 9th, 2016, 6:52
Hi, I am moving activity so I am willing to sell a portable clean room vertical laminar flow in excellent condition:
MINIFIL E Clean Room
from Monmouth
Scientific
Internal dim. 67*60*37 cm
External dim 100*40*67 cm
I am asking for £600 + VAT or best offer excluded shipping.
I also have many tools that would be the luck of anyone who wish to start with DR, will send the list and the price if you pm me.
Thank you
 Post subject: Re: PORTABLE CLEAN ROOM
PostPosted: May 9th, 2016, 7:43
Those are the specifications
Minifil e
Vertical Laminar Flow Cabinet
The Minifil e is a 680mm wide vertical laminar flow cabinet providing
clean air over the worksurface to Class 100 conditions using large
capacity HEPA filters.
The cabinets are extremely cost effective and very easy to install.
The Minifil e is fitted with an EU3 intake filter and an H13 large capacity main HEPA filter offering
99.997% efficiency at 0.3 microns. The cabinets have Astrocell II one-piece gasket dry filter seals, which
are designed for use in clean rooms, clean benches, biohazard benches and other clean workstations.
Specifications
External Dimensions (w x d x h) 680 x 375 x 1132mm
Work area Dimensions (w x d x h) 630 x 350 x 582mm
Construction Aluminium frame with 6mm double laminated
fibreboard infill panels
Intake filter EU3 255 x 480mm Washable polyamide fibre filter
HEPA Filter 610 x 305 x 69mm (H13)
Lighting Fluorescent Strip Lamp 15w
Fan 0.2kw, 0.6A, 230v/50hz
Fan Control On/Off
Weight 35kg
Noise level <52dB (A)
Air Velocity m/s 0.45 (+/- 20%)
Electrical Socket No
Optional UV Lighting No
PostPosted: May 9th, 2016, 7:50
Looks like I am not able to reply to pm due to the fact that this is a new account, here are the specifications:
Minifil e Vertical Laminar Flow Cabinet
Specifications
Fan Control On/Off
Weight 35kg
in case you have any other questions please pm me a way to contact you!
Also I am sorry but I wish to sell in UK or in the worst case scenario in Europe.
thank you
PostPosted: May 12th, 2016, 6:15
A sold everything already thank you!
