HDD GURU FORUMS
http://forum.hddguru.com/
I'm selling SD Flash Doctor 300 $
http://forum.hddguru.com/viewtopic.php?f=15&t=34129
Page 1 of 1
Author:  crystyan_stan [ September 8th, 2016, 7:26 ]
Post subject:  I'm selling SD Flash Doctor 300 $
I'm selling SD Flash Doctor for only 300 $
Flash Doctor SD Flash Doctor - the ultimate solution for Flash Data Recovery
SD Flash Doctor is a professional tool for flash data recovery from damaged flash media (both physical and logical problems). This is an advanced stand-alone flash data recovery kit contains hardware and software: the hardware helps to access the flash chip contains user data despite of damaged controller or any other front ends (PCB, etc.
) using non-standard interface and command, and then extract all the data as an image; the software works on this image and helps to rebuild the data which is doomed to be corrupted because of the "Data Mix" technology used by the manufacturers, Flash Data Recovery Doctor uses unique algorithm which removes the data mix with no need to know/use/emulate/analyze the controller.
That’s to say, Flash Data Recovery Doctor "removes" the data mix directly.
please contact me on crystyan_stan@yahoo.com
Thank you
flash_doctor_sd_flash_doctor_the_ultimate_solution_for_flash_data_recovery.jpg [ 23.53 KiB | Viewed 6268 times ]
Author:  data-medics [ September 8th, 2016, 16:27 ]
Post subject:  Re: I'm selling SD Flash Doctor 300 $
Or you can just take the $300 go to the casino and bet it all on red. At least that way you'll have a 50% chance of getting some return on investment.
http://www.phpbb.com/
