 Post subject: mac air ssd card reader
PostPosted: October 28th, 2016, 0:06
hi,
anyone who are interested in this. you can contact me at sos@thailanddatarecovery.com. we sell it at $14. for details, please see below.
Only works on 12+6 pins 2010/2011 MacBook Air SSD which mainly uses on
Air A1369 A1370 (MC503 MC504 MC505 MC506) MC965 MC966 MC968 MC969.
Not suitable for 17+7 pins 2012 new MacBook Air SSD which mainly uses on
A1466 - 13-inch (MD231, MD232), A1465 - 11-inch (MD223, MD224)
3.3V Regulator Included With Jumper Version.
Apple SSD needed 3.3V Power Supply, Not 5V.
Jumper function as follow:-
1-2 Bypass 3.3V Regulator
2-3 Using 3.3V Reglator (Default)
Please noted that if bypass regulator. MUST make sure your SATA Power Supply Cable can supply 3.3V output
(It have orange color cable on SATA Power cord)
If using Molex Connector (big “Four” Pins) convert to SATA Power connector.
It CANNOT supply 3.3V Power for SSD. Only 5V Power.
If you don’t know, using default setting.
The advantage of bypass regulator is save power and heat.
When you upgrade your MacBook Air's SSD and don't know how to deal with the old one?
Here is the solution for you.
This card is made to convert MacBook Air's SSD interface to standard SATA interface.
Compatible with standard SATA 2.0 hard disk.
Easy install and great quality.
Physical size:132mm x 43mm x 12mm(height) ( Unfit on notebook )
3.3V
best regards,
Users browsing this forum: No registered users and 95 guests
